    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. WarmGuy Feeling the Heat
    Far Northern Calif. Coast
    I got a tutorial from my chimney sweep on cleaning my flue, and I'm going to try it. I'll buy a brush and rod kit on Ebay.
    I assume that I measure the diameter of the flue and get a brush with the same specified diameter. Anything else I should know??
    Thanks,
    #1
    Helpful Sponsor Ads!
  2. RoosterBoy New Member
    CT
    i clean my own chimney also but i have a 8 inch brush. this year I'm getting a new stove with a 6 inch so i have to buy a new brush.
    could you share your tutorial with us. i just want to see if there are any tips i could use.
    thanks
    Jason
  3. suematteva New Member
    We got a plastic/poly brush and the fiberglass rods at the local true value hardware store, like 10-12 bucks for the brush...Was told we did not need the steel one by a couple folks...disconnect the single wall stove pipe where it meets the chimney, use two plastic grocery bags one inside the other, masking tape to keep snug..masking tape stays on the plastic bag...The Mrs..supports the bag and tells me when the brush is there. I usually do this 3 or 4 times, each time I turn the brush a bit.. We brush once a year.
  4. WarmGuy Feeling the Heat
    It was nothing fancy. He just told me that with our model of fireplace (Regency Warm Hearth), that it was easy (some models, not so easy). He said I just brush the inside of the flue, and then vacuum away the creosote which will be deposited here (pointing to smoke shelf).
Thread Status:
