Hello All,
Just had a Lopi Declaration insert installed and on my second burn! So far so good but just had a question about the bypass damper. From reading the manual, it seems like the bypass damper is usually fully open or fully closed. You have it open when you first start the fire or if you are throwing in some more logs but typically the bypass damper is fully closed. However, when the stove was installed, the tech seem to suggest there is a sweet spot for the bypass damper and that it shouldn't be all the way in either direction. For folks with the same stove or have stoves with a bypass damper, what has been your experience?
Thanks,
Andre
Thanks,
Andre
