I'm deciding between a soapstone stove or a cast iron stove to heat a poorly-insulated 800 ft2 space over 3 floors. The main floor that the stove would be on is the bottom floor of three, and it's about 400 ft2. This is the living area and I'm a bit concerned that it might get too hot for comfort. My questions are:
- In your experience, how close can you comfortably sit to a soapstone stove (I'd buy a Woodstock). Is this significantly different to a cast iron one (I'd get Lopi or Jotul)? The stove would be producing about 20,000 BTU and sofa would be about 5-6 feet away from the front of the stove.
- Would a cast iron stove with convective design be better at distributing heat to a multi-story space than a soapstone stove? The Lopi specifically says it has radiant heat but also has a convection opening for air to circulate through.
- Would these stoves use approximately the same amount of fuel to heat the space to the same level?
Thanks so much for any insight! (Note: I'm actually considering a gas stove, but there seem to be a lot more users of wood here, and the general principles should be the same, I think.)
(I did not include any spreadsheets in that post; you can thank me later.)
