Can you use pellet insert in prefab fireplace?
If all of the inserts clearances to combustible materials are satisfied inside the prefab you should be fine to go.
I tore the tin one right out and put the pellet insert in its place. Made for a better install. Still used the pre-existing chimney and routed the flex pipe right up through.
