    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Woodscout New Member
    Eastern PA.
    :rolleyes: Are their any cast iron stoves that are comparable in depth like the Napoleon 1900, or Osburn 2300, stoves. It seems that I can't find a cast iron stove that will accept a 18" or 19" log (north/south loading).
    (Alderlea T6 does not count)
    #1
    Helpful Sponsor Ads!
  2. dafattkidd Minister of Fire
    Long Island, NY
    why doesn't the T6 count? If I'm not mistaken it behaves like a cast irron unit.
  3. begreen Super Moderator
    South Puget Sound, WA
    Yes, we need more info on what you are looking for and what are the issues. Understanding why the T6 doesn't count will help. Is this a cost or space issue? are you looking for a used pre-EPA stove or a currently sold EPA stove?
    Have you looked at the Jotul F118 or F118CB?
  4. Woodscout New Member
    Eastern PA.
    :rolleyes: Hmmmmm. Thanks begreen, brothers finishing up on a newly built home (2800sf) him and wife (wood stove newbies) love the way my Napoleon 1900 excepts long splits with ease (n/s - e/w 18") loading etc. But don't like the looks of my stove (or any steel stove for that matter) AT ALL . Space is not a problem and budget ($3500) seems hefty. As far as the T6 goes, I rather not get into that - lets just say its not and will not be on there list. The Jotul F118 or F118CB I don't think will fit the bill, but will tell them to give it a look-see. However, I did tell them to check out the New Lopi Cape Cod, this is probably the closest they will get to a 3.0 cu.ft. fire box in a real cast iron stove as they put it (whatever that means) but the inside firebox depth from the specs may be somewhat short for them. Just trying to help my brother & his wife out with a little advice. Love my Napolean 1900, but will be getting rid of it after this winter season, but that's another story.
  5. begreen Super Moderator
    The Quadrafire Isle Royale is a nice proven, 3 cu ft cast iron stove. So is the Jotul F600.
  6. dafattkidd Minister of Fire
    Long Island, NY
    Yes, the Isle Royale. That is a beautiful stove. My friend has one. He's a member here as well. That is a very nice unit. It puts out a ton of heat. If I was to buy a stand alone stove, that would be on my short list.
  7. MasterMech Minister of Fire
    Hudson Valley NY
    I've been meaning to measure my Rangeley N-S to see what the actual limit would be but it takes most of my splits N-s no problem. Woodscout, do you dislike all hybrid steel/cast stoves or just the T6?
  8. ddddddden Minister of Fire
    Central Va
    I get what you are saying about there not being many iron stoves with a square firebox, but many do have a side door. Loading E-W through a side door = loading N-S through a front door, more or less. Of course, you don't have as much flexibility as with a square firebox, which allows you to place wood in either direction; but if the stove burns well E-W, and loads easily through a side door, then I'm good-to-go. :)
