Not every time, but a pain when it occurs.
My Castile will start-up drop pellets and ignite, but before my control box light goes green the fire has dimmed enough that my light does not go green.
Sometimes I wondered if it was getting enough pellets at start-up. If you watch the stove while it's up and running OK when the augur pulses sometimes 1 pellet maybe 2 then other-times it seems like quite a few quit so I thought well maybe at start up might I not get a few pulses of a few pellets and hence not a big enough fire to get a green light, and at other times a lot of pellets that result in a good fire and a green light.
I sat there and watched a few start-ups and realized the fire was dimming before getting my green light. I adjusted the feed rate up a little and Wednesday night the stove started and stopped several times before daybreak, and I thought I solved the problem then later in the day Friday it started acting up. The stove has been thoroughly cleaned including removal of the combustion motor and a good clean-out of the exhaust piping. When I do start up and run OK I have a nice robust fire.
I would like to verify that my thermocouple cover is jutting out the right distance into the burn pot. I found a service manual (dated 2002) and it stated 1 3/4" into the burn pot. I took a look and mine is about 1/2", but later this evening it became apparent that at some point Quad changed the thermocouple cover size to a shorter unit so it's got to be less than 1 3/4" for newer stoves.
I have two questions does anybody have the latest service manual. My stove was purchased in the summer 2009? Also in order to verify that the thermocouple wire is inserted all the way into the cover and touching the end do I just loosen the screw at the base of the thermocouple? It looks like it's a clip that hold the thermocouple wire by just pinching it.
