Changing Door Gasket
learnin to burn
347
Southeastern, Pa
I'm about to replace my door gasket. (my first time changing a door gasket) I have Home Saver Stove Gasket Cement. The directions say to moisten the gasket and metal with water. Is that necessary?
If so what's the best way for doing this?
Yeah..."moisten", not "drench".
Clean the surface real good with a wire wheel. The cement only sticks as good as the surface you apply it to. I hate that chit myself. Been using silicone and like it much better.
If you can take the door off and lay it flat, makes it a lot easier to pack it into the channel.
steve
