Chemical Smell?
jcleary47 Posted By jcleary47, Dec 7, 2012 at 8:56 AM
  1. jcleary47
    jcleary47
    Member 2.
    NULL
    Feb 21, 2012
    42
    3
    Loc:
    Gorham, ME
    Whenever I run my stove on the highest setting, there's a smell that develops and is almost like a chemical-like smell of something burning off. They did tell me that there would be a smell when I first started it up, but I've put about a ton of pellets through it so far. I only detect the smell when it's running on the highest setting.
    I haven't run it that high very often, but enough where I'd think it shouldn't be there?
    I'd equate the smell to be similiar to when you fire up a toaster or toaster oven for the first time and it burns off the residues inside.
    Any thoughts?
  2. bonesy
    bonesy
    Feeling the Heat 2.
    NULL
    Oct 6, 2011
    299
    34
    Loc:
    NE PA
    I would say it is fairly normal. I get the same thing on my BigE if I run it on level 5.
  3. moey
    moey
    Minister of Fire 2.
    NULL
    Jul 12, 2012
    1,345
    329
    Loc:
    Southern Maine
    May be that on high you are heating up portions of the stove that under the lower settings are not getting hot enough to produce the smell. My stove stunk for about the first ten bags or so.
    SmokeyTheBear likes this.
  4. AbetterChimneynm
    AbetterChimneynm
    Member 2.
    NULL
    Apr 20, 2012
    173
    12
    Loc:
    SIlver City, New Mexico
    When we install a new stove for a customer, we always tell them to burn the stove on high for 1 to 5 hours depending on stove etc to burn off the "new stove smell" we always have them do it in the middle of the day with the windows open and fans on so that it does not over power them and for the most part that takes care of the smell.
  5. SXIPro
    SXIPro
    Minister of Fire 2.
    NULL
    Sep 28, 2009
    705
    219
    Loc:
    Northern MA
    And if they have pet birds, I hope you tell them to move them somewhere safe. Otherwise you may get the old 'canary in the coal mine' outcome.
  6. jcleary47
    jcleary47
    Member 2.
    NULL
    Feb 21, 2012
    42
    3
    Loc:
    Gorham, ME
    Thanks for the tip, I don't usually turn it up that high but maybe I'll crank it up in the spring to see if I can get it to burn off when I can open up the windows and stuff.
  7. CT Pellet
    CT Pellet
    Minister of Fire 2.
    NULL
    Dec 1, 2012
    667
    501
    Loc:
    Torrington, CT
    Also, if you lubricate the distribution fan with a spray lube, as opposed to the "oil drop can" that you are supposed to use, then you will smell the oil that you ended up spraying on the fins that never should have been there to begin with. Just another possibility.
