Well, after some warmer temps and not burning my Quad 4100I for a few weeks, I fired it up this morning.
Had an issue getting a good draft "poor wood" at the end of the season. I know, I shouldn't but i'm out. Not GREEN, but a little wet from rain.
Anywho, had the door open and not paying attention. Heard a "blow torch" type sound. Look across the street at my neighboor, his wife points at my chimney, says something to her husband, they get in the car and drive away. Thanks for not saying anything, guys.
I think "uh oh." I look inside the stove and see red inside the chimney connector. Look at the liner and see a spot of glowing red.
Run outside and see nasty looking creao hanging from the chimney cap. And, I see some smoke coming from around the liner, thats right, not from the cap, but from where the cap seals to the chimney. Burning the caulk maybe?
Mind you this all happens fast. I grab the fire extinguisher, Fill the stove with it and close the door and air. Everything goes out, and cools down. I climb on the roof, no damage, I climb in the attic and feel around, no heat. Pull the surround off the insert, inspect the liner...didn't seem to be damaged, from what I can see.
My concern, that there was some smoke coming from around the liner base plate, where there is a small hole of missed caulk. I'm concerned that the liner was damaged. The installer had a hard time getting it down the chimney, is it possible it worked a weak spot, and then the chimney fire finished it off?
Stove is cold, and remaining that way until I find a solution.
