The insert is ready, the flue is clean and I'm ready to order the liner. But there are a few types and I don't fully understand the differences and applications. What I'm working with is a exterior masonry chimney. 20' tall and an unlined flue that is 18"x18". Pretty much a straight shot to the stove but the liner will have to make a bend to clear the damper opening.
1. It seems that 316ti and 316L are common materials for liners. Which is better?
2. Should I get 1 ply or 2?
3. What thickness? It would seem that the thicker the better but will I run into problems bending it? There seems to be .005, .006, and .013 thickness available.
Last question is about the smoke shelf in the chimney. After I cut the damper out and opened up the hole I was able to get a shop vac back in there. I vaccumed out a load of junk and probably 75 years of chimney cleanings. Should I try and get some concrete or sand back in there or just leave it alone since I am lining anyway? Opening behind the smoke shelf is probably 1' deep and the width of the firebox (28").
