Chimney Stove connector pipe???
NVHunter
292
Reno, NV
Ok, Im looking at installing a Ashford or Sirocco 30 Blaze King stove in the near furture. The manual for the stoves says to use a 24 gauge MSG Black/Blue Steel stove pipe to connect the stove to the chimney (UL 103 HT rated chimney). I'm looking at using the DuraTec Stainless Steel Chimney.
The manual then recommend using a double wall connector pipe.
My question is, I've been looking at using the Duravent DVL double wall close clearance stove pipe. Is this pipe acceptable to use for these stoves? I've looked and it says the inside pipe is 0.016" thick steel and the outside pipe is 0.018" thick steel.
I don't know anything about chimney connector pipe so any help would be appreciated.
Are all brands of chimney pipe and chimney connector pipe similar in dimensions (for example, elbows are same size, diameters are the same ect...)
Thanks, and sorry if these questions are stupid or don't make sense.
I'm a newbie...
DuraVent DVL is a good choice for connecting this stove. Note that you can not mix and match brands. If your chimney is DuraTech, stick with a DuraVent adapter and connector to the stove.
