    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. JCass New Member
    SLC, UT
    Is there any damage that can be done by sweeping your chimney?
    #1
    Helpful Sponsor Ads!
  2. PLAYS WITH FIRE Feeling the Heat
    Pittsburgh, Pa.
    If you push the brush too far and bust up you baffle.....mine has a bracket welded on to the collar so you can't and baffle is made of ceramic fiber.
  3. KaptJaq Minister of Fire
    Long Island, NY
    Aggressively using too stiff of a steel brush in a flexible stainless liner can cause rips or the seams to open. Maybe not the first or second time but eventually. Especially if the brush is too large for the liner.
    I use a nylon brush on my SS liners...
    KaptJaq
    etiger2007 likes this.
  4. webby3650 Minister of Fire
    southern Indiana
    Yes you can cause some damage. Both the things mentioned above are probably the biggest concerns. We have a local chimney sweep we jokingly call Baffle Busters Chimney Service. I have had to replace a few, a few in Hearthstones and at least one Jotul.
  5. pen Super Moderator
    N.E. Penna
  6. Beer Belly Minister of Fire
    Connecticut
    uh oh....while cleaning mine this fall, I noticed about half way down my brush seemed to be a loose fit, and then tightened back up when I went down another foot or so.....I was thinking there may be a seperation somewhere in the middle, but thought ..."nah, how could that be"....and never shined a light down there to look due to all the ash filling the flue
  7. pen Super Moderator
    N.E. Penna
    I know what you are going to be up to today <>
  8. begreen Super Moderator
    South Puget Sound, WA
    Short answer is yes. There are definitely several opportunities to mess up a chimney cleaning, and to mess up the house too. What type of chimney or liner do you have JCass?
  9. JCass New Member
    SLC, UT
    I have a ~15ft SS flex liner run down an exterior chimney. My main concern is separating the junctions within the SS liner.
  10. begreen Super Moderator
    Burn clean dry wood and use a poly brush. Should be ok.
  11. bag of hammers Minister of Fire
    Northern ON
    poly brush - I also (now) make sure I remove the temp probe in the stove pipe first (don't laugh...)...
  12. Backwoods Savage Minister of Fire
    Michigan
  13. WhitePine Feeling the Heat
    Sorry, couldn't help. Sounds like something I would do. ;lol
