    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. nrcrash Member
    MA
    After I fire up my Vigas 40, while flue temp is increasing between 220- 270 degrees (approximately). I get a deep humming sound. I installed a barometric damper because I though this would help but it continues to do it. Wasn't sure if this was normal if it is something I should be concerned with.....
    #1
    Helpful Sponsor Ads!
  2. maple1 Minister of Fire
    Nova Scotia
    Humming?
    Or rumbling?
    Gassification produces a rumble - I kind of like it. :)
    (That's the way it is here - so I hope it's normal...)
  3. JP11 Minister of Fire
    Central Maine
    I've gotten a similar sound. I always thought it was right around when gasification starts. BUT... in my case I thought it was from the cardboard I'm using (wife's business generates a ton) was really roaring.
    don't know
    JP
  4. Nofossil Minister of Fire
    Addison County, Vermont
    I've had what I think you're describing. Happens on startup when there's a vigorous fire in the upper chamber and you switch to downdraft operation. I *think* what's happening is the flame front is switching from above the nozzle to below the nozzle, back and forth. This gets the air column in the chimney vibrating like a giant pipe organ. Not a gasification rumble - more like the helicopter of doom hovering over your chimney.
    Increasing fan speed and/or primary air seems to solve it in my case.
  5. BoilerMan Minister of Fire
    Northern Maine
    I liked the Helo of doom thing.............. LOL great explination!
    TS
