I have a big decision to make on project #2 in my home. I want to obviously think this through and get all the advice I can.
Here's my situation. 1050 sg ft of semi-finished basement and finished 1st floor, same. Chimney runs up through the center of the house with the top 10 ft or so exposed to a cold attic and outside. 20 year old construction. Previously had an older Buck woodstove in the basement. 8" round out of the stove going vertical 4 Ft then horizontal 4 ft then up through square tiled flue 7 x 7 for about 25 ft. The current 7 x 7 tile is not usable and must be religned if used and a new stove purchased to match the liner.
I'm not nuts about the horizontal runs and the height, but I didn't build it. I was considering going with a pellet or multi-fuel stove. If I line it with 6" can I safely and efficiently hook up a pellet to hat flue at that height and design or is it not going to work? Let me back up a second. My goal is not neccessarily to heat my whole home from the basement but rather just keep the chill off and occassionally maybe spend an evening downstairs in the winter witout freezing.
I have a current forced air oil furnace nearby the area the stove was positioned with a 4 flue large chimney, 3 of which are open. 1 appears to be capped off. Might have been installed for an appliance other than a stove since it appears to be smaller in diameter.
My concern with installing a 2nd wood stove is that it appears keeping that old tile chimney hot enough looks like it may have been an issue. It's glazed with a thin layer. I realize that a SS liner would most likely improve on that but I also don't want an install that is going to be a problematic setup. That's why I was going to opt towards an alternative stove.
I've considered add on furnaces as well as LPG through the existing setup, after needed repairs of course. If we line it with 6" SS am I going to limit myself to a woodburning stove 6" or would I be able to go the other way with the pellets, LPG or ?
I also have a wood insert upstairs that I use in the evenings. My furnace thermostat is in the same room, so the furnace doesn't run when burning it. Hence the need for some means to take the edge off the basement, if needed.
I know there's alot of if's and's and but's here. I'm really up in the air about how to proceed and could use some guidance.
Thanks everyone!
Thanks everyone!
