Cleaning class A chimney
MaryAnn Posted By MaryAnn, Feb 26, 2006 at 5:07 PM
Thread Status:
  1. MaryAnn
    MaryAnn
    New Member 2.
    NULL
    Nov 30, 2005
    47
    0
    Plan to have inspection and cleaning done yearly. Would it be a good idea for us to clean chimney periodically also? Do you have to remove the baffle to clean chimney? We have some chimney sweeping logs. Are these better to use at end of season? We burn 24-7.
  2. MountainStoveGuy
    MountainStoveGuy
    Minister of Fire 2.
    NULL
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    CSL's are only good for glazed cresote. If you have a slip joint in your interior chimney pipe, slip it up and tape a plastic bag on, then you wont sweep all the cresote in your stove.
  3. MaryAnn
    MaryAnn
    New Member 2.
    NULL
    Nov 30, 2005
    47
    0
    Is a slip joint the same as a telescoping length of stove pipe? We do have that. Good idea. Thanks.
  4. MountainStoveGuy
    MountainStoveGuy
    Minister of Fire 2.
    NULL
    Jan 23, 2006
    3,654
    2
    Loc:
    Boulder County
    Yep, telescopes work the same way. When the pipe is up, also take your vac and clean the top of the baffle if you have one. Good luck! One more thing, if your baffle is a material other then metal, be careful, it can be fragile.
Thread Status:
