I am planning on cleaning top down and I would like to avoid taking any double wall pipe apart, because it requires me to slide it together to shorten it and the black pipe gets scratched. I cleaned top down with the double rope method one time before and it worked well. I had taken the double wall pipe apart in order to install a pipe damper, which caused scratching of the pipe. The damper was installed directly above the stove on the collar, top exit Jotul F3cb.
So if I clean from the top down is it sufficent to clean to the damper?
I have the Jotul f3cb, do I have to remove anything inside the stove, or is it sufficent to stick my shop vac hose over the baffle plate and suck up the fallen creosote?
Will the flex rods or 1/2 pvc make it through two 45 degree elbows with a piece of two foot pipe in between? (double wall- located in living room) Chimney is approximately 30 feet, class A.
Any help appreciated. John
