clearances to non combustible wall?
rkennedy270
1
mb, canada
i have an old marquis stove which is sitting in an unfinished basement now, but i want to finish it soon. the clearances on this stove are quite large. i was wondering if i make the area around the stove non-combustible, do i still need the 36" of clearance. is there any limit?
I'd like to know this too - I've got a different stove, but I'd like to do the same thing.
I do believe that clearances are to combustibles. That being said, your insurance company and local officals may have something to say about it as well. I am sure that someone here will give you a solid answer.
It isn't as simple as non-combustible. If you put a steel plate (non-combustible) flush against a paneled wood wall, that wouldn't increase your clearance...the steel would conduct heat to the wood. Usually a stove manufacturer will specify a reduced clearance with a heat shield. I'm not sure how you would convert 36" free air clearance to an R-value of insulation between the stove and a combustible, but I'm sure someone else on this site will.
personally, I was wondering if you steel studded a wall, then put a non-combustible face on the wall, what should you be able to get down to; on a concrete floor.
EDIT: --Looks like BK answered my question. Thanks!
