Condensing Stove - No Chimney
jebatty Posted By jebatty, Jun 11, 2013 at 5:29 AM
Thread Status:
  1. jebatty
    jebatty
    Minister of Fire 2.
    NULL
    Jan 1, 2008
    5,347
    695
    Loc:
    Northern MN
    hobbyheater and BoilerMan like this.
  2. stee6043
    stee6043
    Minister of Fire 2.
    NULL
    Aug 22, 2008
    2,548
    241
    Loc:
    West Michigan
    I wonder if municipal water treatment facilities would have an issue with the discharge from a unit like this? Surely one would not make a difference but if every other house had one it might be a different story.
    Neat technology though. I'd like to see one run. I'd also be interested to know how much water and electric such a unit uses...
  3. ridemgis
    ridemgis
    Burning Hunk 2.
    NULL
    Jun 14, 2012
    237
    81
    Loc:
    South Kingstown, Rhode Island
    Way cool! Wonder what happens when the power goes off during a burn. Sure, the fire will choke out pretty quickly, but where does the smoke and heat go in the interim?
  4. BoilerMan
    BoilerMan
    Minister of Fire 2.
    NULL
    Apr 16, 2012
    1,717
    325
    Loc:
    Northern Maine
    Very interesting Jim! I'm curious about the water and pumping wattage needed, but the concept is GREAT and simple. I wonder how startup is as far as the condensate is. The idea that he was useing a plastic vent hose with a wood fire just makes me grin. In theory this type of scrubbing means wouldn't even soot up the wite vinyl siding like all the pellet stoves I see do.
    TS
  5. heaterman
    heaterman
    Minister of Fire 2.
    NULL
    Oct 16, 2007
    3,355
    622
    Loc:
    Falmouth, Michigan
    Looks to me like one of those things that's a good idea..........................on paper. Too many things have to work right for it to function as expected.
    Solid fuel of any kind and condensing level efficiency go together like fried onions and birthday cake. Each of them are good by themselves but never together.;)
    Frozen Canuck, skfire and ewdudley like this.
  6. TCaldwell
    TCaldwell
    Minister of Fire 2.
    NULL
    Oct 26, 2007
    748
    66
    Loc:
    860-868-9014 h 203 948 0864 c nw corner ct.
    being a wood stove,suspect or intermittent secondary burn assumed, what happens to the carbon monoxide created by a suspect secondary burn, does that somehow cling to the water also. This basically washes the fluegas and in doing so manipulates the fluegas temp to create a high effiency on paper. as you can see by the water residue the fluegas analyser is not actually reading the combustion process, but the result after being washed. please correct me if i am wrong
    BoilerMan likes this.
  7. jebatty
    jebatty
    Minister of Fire 2.
    NULL
    Jan 1, 2008
    5,347
    695
    Loc:
    Northern MN
    The efficiency claim may be a question of definition of efficiency. As presented by the Hughes stove article, it appears to be defined as capturing the heat from combustion and not by combustion efficiency plus capturing the combustion heat. But there is nothing I see in the concept of water jet induced draft and scrubbing which would prevent this idea from being used in a high efficiency gasification boiler/stove, which I believe attain combustion efficiency of 98% or better as well as overall efficiency at 80% and up based on flue gas temperatures approaching the condensing level. But if the flue gas also was condensed and scrubbed with the heat captured by a heat exchanger, as employed in the Hughes stove, then efficiency could approach the high 90% range.
    What was interesting was the concept of water jet scrubbing and heat capture. Take that wherever it leads. With an efficient gasification process, CO and H would be near 100% combusted, the solid emissions captured would essentially be the uncombustible fly ash, and what would be left to go up the stack would be CO2, Nitrogen variants and H2O, all at very low temperature.
  8. TCaldwell
    TCaldwell
    Minister of Fire 2.
    NULL
    Oct 26, 2007
    748
    66
    Loc:
    Understanding the health emision reduction, a great benefit, but i would be concerned if central boiler claimed with this technology 100% effiency, kind of loik painting the car before fixing the dent.On a already efficiently designed boiler this could be the only improvement left, on a cb they are missing a few steps. Cb is used as a example of a design that could stand combustion improvement.
  9. BoilerMan
    BoilerMan
    Minister of Fire 2.
    NULL
    Apr 16, 2012
    1,717
    325
    Loc:
    Northern Maine
    I'd take fried onions over birthday cake any day!
    The particulate and CO with questionable secondary burn at times is simply washed down the drain.... So where does that end up? Instead of being released into the atmosphere and then percipitated back to earth by means of rainfal, we just pipe it to the earth...... Still looks neat though!
    TS
  10. TCaldwell
    TCaldwell
    Minister of Fire 2.
    NULL
    Oct 26, 2007
    748
    66
    Loc:
    for clean air it is a good, espically in industrial apps that would otherwise be unfeasable, small manufacturers should focus on known effiency practices before turning to this, just my 2 cents
Thread Status:
