    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    I have a standard wood burning fireplace that I'd like to convert to a gas fireplace. When the fireplace was originally installed [by the prior homeowner] a gas line was also installed [and is currently capped off] in case a future conversion was desired.
    What things do I need to consider in order to pursue this? What costs would be involved?
    I've read a lot about gas logs but am unclear as to whether they alone would do the trick. Do I need a fireplace insert and gas logs? Also, my fireplace is open from one side as well as from the front. Will I lose the side view if I convert to gas?
    Answer:
    If you are mostly looking for the view of a fire (not heat) then a set of vented logs should do the trick. Expect to spend from $300-$700 for the logs plus $200+ to install, assuming gas line is nearby. You will be able to see the logs from both the front and the side.
    #1
    Helpful Sponsor Ads!
Thread Status:
