    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    question:I live in a 70 yr old house; at some point- the fireplace was converted *from gas to wood* and as part of this the fireplace was made smaller by the addition of bricks (presumably firebrick). These bricks are quite clear around the sides; I don't know whether the brick at the back of the fireplace is original or newer. When we opened up the fireplace to light the first fall fire- we saw a crack at the back - about 18 inches- coming up from the bottom. How serious is this? Should we not light a fire until it's fixed? Thanks! Pat Stephenson
    Answer:
    Small cracks are usually not serious- as there is commonly more masonry behind that. To be as safe as possible- use refractory cement (available at your local masonry supply or stove shop) to patch the crack. If you are unsure of the safety of the construction- be sure to have it certified by a local chimney sweep.
    Check your local Yellow pages or the link below for certified chimney sweeps.
    Link: Search For Certified Sweeps
    #1
    Helpful Sponsor Ads!
Thread Status:
