Creosote issues with newmac cl86
crowellsr
7
Ontario
I have a newmac cl86 wood/oil combination and it seems to be a creosote factory. I'm burning two year old maple and beech and the fire gets so hot that you can barely stand to have the firebox door open for more than a split second. I also have no issues keeping the house warm during the winter. It gets quite a bit of creosote build up (more than I think it should get). I checked the flue draft and it is -0.04 to -0.06 where the manual says minimum -0.03 maximum -0.05. It currently has a single wall 8 inch flue with two 45 degree bends and a barometric damper in between.
Any help would be greatly appreciated.
Is there any difference in creosote before and after the barometric damper ? Does the barometric damper door is full of creosote ?
I didn't notice when I took it off to clean it whether one end was worse than the other. The barometric damper door does get a little bit of creosote on the back of it but nothing like the inside of the flue pipe.
You say you're burning 2 year old wood. Has it been split for 2 years or was it in blocks and recently split?
The creosote only seems to build up in the flue pipe, I don't seem to get much in the outside insulated chimney. The wood has been split for two years and I periodically check with a moisture meter
It's only been a little over a month since the last cleaning. I'm pretty new to wood burning so I'm trying to avoid any problems I can
Would you say that it is building up in the area or adjacent to where the pipe attaches to the masonry thimble. Masonry is a big heat sink and could be cooling the pipe where it slips in to the thimble.
I assumed this was going into a masonry chimney. No?
I guess I missed that! Sorry!
