If the masonry chimney is on the exterior of the house waterproofing the exterior bricks can stop a lot of the smell. The bricks could be absorbing moisture, making that wet creosote smell a lot worse.
Thanks
Thanks
It is very possible the smell is being made worse by moisture but if it really is limestone like she said i doubt sealing will do any good if there is water coming in it is extremely unlikely that it is soaking through the limestone it would be coming from the top which may need a crown or top plate through the mortar which would mean re pointing or from moist air from inside which would be fixed by a blockoff plate. I have seen very few cases where waterproofing was needed or would make much of any difference. Although we just did a sandstone chimney today that really needed it but sandstone is very different
I have an insert but no liner. For the first few years my living room smelled like creosote. Since then i have left the last burn ashes in the stove all summer and that seems to absorb the odor unless its raining or extremely humid. I dont really mind it but my girlfriend does!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
