Cultured stone behind stove and pipe
Henk
2
MN
Hi, I'm in central Minnesota. I put in a Lopi double door wood stove with 8" pipe on a straight wall.
The stove pipe is 21" from the studs and straight up with proper through ceiling set up.
I'm think of putting up 1/2 " durra rock and 1 1/2 to 2 1/2" thick cultured stone, with a 3/8 to 1/2 " mud joint.
So after it's up, the stove pipe would be about 17 1/2" from the stone.
Does this fly with safety and codes and everything ? ( clearance to combustibles ? )
What are the actual rules ? ( So many on internet. Which is "RIGHT" )
Also, what alternatives to stone are there, with safety in mind ? Like metal, or brick. or ????
Maybe go that route.
Thanks very much.
Henk
The clearance for single wall pipe is 18" to the nearest combustible which should be the wall studs behind the Durock. If you want more protection, use double-wall stove pipe with 6" clearance.
