    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. keyman512us Member
    North Worc. CTY MA
    Hey all...
    Don't know how usefull this topic is... but if your Locale is like mine it might be.
    Up here on the hill in G-Vegas (Gardner) it's hard to find a consistent weather forecast. I'm 60 miles from Beantown (where all the TV stations are) 30 miles from the county seat (Worcester and the 'local' radio stations) so weather broadcasts are as useless as commercials.
    So while surfing the web for something else...low and behold I stumble across this little gem:
    http://www.airport-data.com/airport/GDM/weather.html
    Best thing to have stumbled across, told quite a few friends and they added it to their 'favorites' as well to get a real close weather forecast.
    So if you are in the same boat... and have a small airport close by it may be worthwhile to locate the airport closest to you... keep in mind even if you don't think there is an airport close by... it also lists heliport approved sites (from hospitals to personal ones)
    For those in the same situation and are looking for good weather info, check it out... and post if it's on the money. ;)
    http://www.airport-data.com/states/index.html
    "For frequent Flyers" Keep in mind that site also lists the "big ones too" so If you are flying int o LA from Boston or vice versa.... you can check on the conditions. ;)
    #1
    Helpful Sponsor Ads!
  2. keyman512us Member
    North Worc. CTY MA
    As a Comparison table... Conditions at Boston Logan BOS:
    Fair 57°F
    Wind: WNW at 4 mph
    Humidity: 61%
    Pressure: 30.17 in. falling
    Dew Point: 44 °F
    Visibility: 10.0 mi
    UV Index 0 Low
    Current weather condition updated: 8/19/07 4:25 AM EDT
    Gardner MA... GDM:
    47°F
    Wind: SSW at 2 mph
    Humidity: 83%
    Pressure: 30.21 in. steady
    Dew Point: 42 °F
    Visibility: 10.0 mi
    UV Index 0 Low
    North Attleboro- 2MA7
    Clear 51°F
    Wind: calm
    Humidity: 76%
    Pressure: 30.17 in. steady
    Dew Point: 43 °F
    Visibility: 8.0 mi
    UV Index 0 Low
    North Adams- 32MA
    Clear 46°F
    Wind: calm
    Humidity: 95%
    Dew Point: 45 °F
    Visibility: 10.0 mi
    UV Index 0 Low
    Conditions updated (from 4 AM to 4:25)
    N Adams rose 1 degree... Gardner 2 degrees Humidity vary quite a bit???
    Might not seem worth the time... but if you have a boiler or an old smoke dragon these numbers can help with how to fire accordingly...
Thread Status:
