    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. hydestone New Member
    How air tight must a damper blank-off kit be when a wood stove is installed into an existing fireplace? I cannot seem to get it completely air tight...there are a few gaps where it will not seat properly due to the shaped of my existing damper frame. Should the gaps be sealed off with fire caulking or are they OK?
    #1
    Helpful Sponsor Ads!
  2. hydestone New Member
    Is it simply meant to be a thermal break? I.e. insulation with a plate below? Must it stop all air penetration or just the bulk of the free area?
  3. elkimmeg Banned
    I would caulk it with 1000 degree rated caulk or higher or refactory cement in a tube.
    Sealing becomes even more critical if not fully lined and not blocked of at the top.
    The last thing you want is the exhaust escaping back into the living area
  4. hydestone New Member
    Thanks ELK. I appreciate all your feedback and advice.
  5. elkimmeg Banned
    one final word of advice do not use the red RTV caulk> It is only good to 300 degrees We had one incident in my
    town already where it ignited. Did not do too much damage but scared the hell out the guy and caused minor
    smoke and fumes problems in the room
    What you might want to look for is a draft sealant Caulk there is a Standard called 136 Which is to draft seal and to be able to withstand 1200 degrees. One company that makes it is Boss
    Boss 136 Firestop Draft Sealant tested to withstand up to 3000 degrees
    Found at Home Depot
    3M Fire Block Sealant FB 136
    I know Rutland also makes a 136 compliant Fire stop Draft sealant as well
  6. wingnut New Member
    I plan on using the leftover ceramic insulation from my install and packing some around the insulated pipe at the top before I cap it. Can I do the same thing at the bottom of the stack just above the smoke camber? Would this help for a better seal?
  7. Rhone Minister of Fire
    My block-off also did not fit exactly tight particularly the left & right sides. There was about a 1/2" gap on the left in particular. I ended up stuffing it with mineral wool insulation and I mean stuffing it to be nearly rock solid. Not the best option, but better than leaving it how it was. When I redo my install & liner this year I'll see about caulking it or getting a bigger block-off.
Thread Status:
