damper or intake
brokeburner
143
southern ohio
I burn a old stove when you hit about 500 600 degrees stove top thermometer do choke down the air first or the damper
Is this the first time you have used this stove? Have you had any problems and if this is a new house with an old stove be sure to have the whole system checked out before using it hard. You will have to experiment but I would shut the air supply down first. You need to find out how your stove behaves. Do a couple of overnight burns with the damper open to see how it does. Later if you need to get longer burns start experimenting with the damper. I suspect it has a damper because it has trouble getting long burns. Eventually you will probably find a position for the damper that you can always use. Sometimes people have dampers just so they can slow down a runaway or chimney fire. Having one does not mean you have to use it. So there are many options. Good luck
