    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. mick sutton New Member
    I have an old Defiant II with a gaping hole where a piece fell out of the lower fireback. I managed to find a replacement part online, but it came without installation instructions. It looks to me as if both the stove back and top need to come off. I have managed to loosen the four screws in the stove back but am at a bit of a loss where to go from there. I haven't found anything in the discussion threads that quite address this problem. Does anyone know where I can get hold of installation instructions?
    #1
    Helpful Sponsor Ads!
  2. begreen Super Moderator
    South Puget Sound, WA
    Start a conversation with Defiant if he doesn't catch this thread. He can help you out with this one.
  3. defiant3 Feeling the Heat
    No. NH
    So I don't believe there's a repair manual any more, but there IS a pamphlet that comes with the Defiant II fireback kit called," Defiant Top To Bottom" or something similar. That should be helpful, and feel free to ask me anything if it's unclear. I'll tell you that replacing only the lower f.b. will likely be a problem. The other parts in there are not going to be as straight as the new part, so will not fit together well, if at all. Give yourself a break and get the whole fireback kit. Trust me. Part number is 5837. And instrutions will come with, how good is that?
    Defiant and remkel like this.
  4. peakbagger Minister of Fire
    Northern NH
    I have done it twice and it requires disassembling the entire stove. That is not a bad thing as you will end up resealing the stove and sealing up the secondary air tube which is one half composed of the two ribs on the back of the fireback. When you are done you effectively have a new stove. It takes me about 8 hours with most of the time spent scraping and wirebrushing all the old stove cement out of the joints. Its a great tiem to paint the stove. I use a small electrci angle grinder and a course wire disk for most of the work. It is messy and I would recomend a dust mask at a minimum and possibly a HEPA respirator as I think stove cement contains a lot of silica.
    Defiant likes this.
  5. mick sutton New Member
    Thanks for the helpful responses. I don't have a whole lot of experience at this sort of thing but I'll probably order the Defiant fireback kit and give it a go.
  6. peakbagger Minister of Fire
    Northern NH
    The instructions with the kit are great, they assume that you are beginner.
    Defiant likes this.
  7. defiant3 Feeling the Heat
    No. NH
    And we're always here to help as long as our hands don't have to get dirty...
