1. raygard Member
    Columbia, MD
    This is an FYI.
    So we all talk about temperatures and what not, but how do we write the degrees symbol. If you are like me, that is someone who is rear ended, you can type your number eg. 625
    and to get the degree symbol raised you hold down the ALT key and then tap 2...4...8 on the number keypad on the right hand side of the keyboard (it doesn't work with the number at
    the top of the regular keys).
    And there you have it, another tip from Ray's book of useless facts
    Ray
  2. oldspark God of Fire
    North West Iowa
    I just use the one in the smileys.
  3. mtbon New Member
    CT
    I use ALT 0176. You saved me a keystroke! Thanks!
  4. JotulOwner New Member
    Long Island, New York
    ..... or, you can just type "degrees" and be done with it.
  5. Stephen in SoKY Feeling the Heat
    Southern Kentucky
    I don't have a number pad on the right hand side of the keyboard.
  6. begreen Super Moderator
    South Puget Sound, WA
    Got Mac?
  7. BrotherBart Super Moderator
    Northern Virginia
    °C
    °F
    From the smileys works for me.
  8. precaud New Member
    Sunny New Mexico
    or forget the degree sign and just append C or F so we know which you're referring to...
  9. realstihl Member
    eastern kansas
    Laptop, no numbers on right side. I think there is another way, haven't looked.
  10. drfera Member
    And when you need to express degrees Kelvin? %-P
    Like BG said, "Got Mac?" For the degree sign on the Apple keyboard it's simply "option" plus "zero".
    Also, on the iPhone you just keep your finger on any character on the QUERTY touch keyboard until you see the various options for each character displayed to the left. For the ° sign the correct key is the "zero" key. Below are the options for the letter "O":
    o ô ö ò ó œ ø Šõ.
    Pretty cool, eh?
  11. drfera Member
    BTW Ray, I think I've found you sig line inside a fortune cookie. :lol:
  12. jeff_t God of Fire
    Milan, Michigan
    Or, with the android keyboard, from the number keys tap ALT and find the ° the there. Or use the smileys.
    Edit: sorry about the extra 'the'. Stupid android keyboard.
  13. NextEndeavor Member
    Southern Iowa
    What about my new iPad this Windows guy is trying to figure out?
  14. BrotherBart Super Moderator
    Northern Virginia
    I just draw the degree symbol on the screen with a Sharpie.
  15. WoodNStuff New Member
    South Central WI
    You should be able to pull up the virtual keyboard, right? Then hold down the "option" key and press "0" (zero). You should get this character º. Or in context 650º.
  16. nate379 God of Fire
    Palmer, Alaska
    I use a *. Where are there smilies?
  17. realstihl Member
    eastern kansas
    °F That was easy!
  18. webbie Administrator
    Western Mass.
    The little link on the left of messages....
    :coolsmile: :coolgrin: :roll: >:-( :ahhh:
  19. DanCorcoran God of Fire
    Richmond, VA
    What do you mean, "on the left of messages"?
  20. toonces Member
    Farmington Valley, CT
    option + 0 (zero) = º
    shift + option + 8 = °
    for Macs. not sure which is the degree symbol. i just mash the keyboard till i see it.
  21. billb3 God of Fire
    SE Mass
    Mac : option -k works, too sometimes makes a tinier symbol
    32 Ëš (option -k)
    32º (option -0 (zero)
    "smileys" is under "message" if you open a reply window
  22. fossil Super Moderator
    Bend, Oregon
    When you click on "Reply", or "Quote", you open up a box into which a response may be typed (I'm doing it right now...as you have done many times). While I'm in the "Post a New Reply" box, I see, just to the left of the box, the word "Smileys". Click on that, and a pop-up box appears containing the available smileys. Clicking on a smiley will insert it into your reply message wherever your cursor is currently located. :)
  23. fossil Super Moderator
    Bend, Oregon
    For a degree symbol...and a whole lot more things...I use ALT-codes. directories of them are available by simply Googling "ALT codes". ² ³ ½ ¼ ¾ ° ± etc., etc.
  24. NextEndeavor Member
    Southern Iowa
    Okay, from iPad: it's only 10° outside provided only from solid fuel grown by nature between 32° and 100° then carried inside where it's a comfortable 75° !
    Thanks for the typing assistance
  25. firefighterjake God of Fire
    Unity/Bangor, Maine
    HehHeh . . . true story . . . when I was hired at the fire department I had to do a short safety presentation to show that I could teach and knew something about fire safety.
    I offered a short presentation on where to place smoke detectors and had the Assistant Chiefs and Fire Chief mark where they thought smoke detectors should be placed in a diagram of a house that I had on a transparency . . . it all went well until the Fire Chief took the marker and made a dot on the screen -- instead of on my transparency.
    That red dot is still on the screen in the classroom. :)
