Hello Fisher fans. I've installed a rear-vent Grampa Bear in my shop and I'd like some guidance getting my burns dialed in.  I have a straight up 20' 8" chimney (9' of single-wall and 11' of double-wall class A).
I installed a baffle last night.
My biggest concern right now is flue temperature. I loaded the stove last night with 7 splits on top of a bed of coals. I have a probe thermometer in the flue and it only topped out at 580* and it dropped down to about 300* within 30-45 minutes. The lower stove top was 550* and stayed there for a couple of hours. That seems like a low stack temperature to me - I'm measuring about 18" up. I do have a key damper in the pipe but I left it wide open.
I did not measure my stack temperature before installing the baffle.
I'm thinking the gap between my baffle and the stove top might be a little too tight. Do those stack temps seem ok, or should I widen the gap a bit - it's about 2" right now.
The other thing is smoke. After the fire settled in and my stove-top temp was sitting at 550*, I had lots of smoke from the chimney. After about 2 hours, it cleaned up dramatically with almost no visible smoke. I have my draft vents open about 1/2 turn. What can I do to clean up the burn earlier in the cycle?
thanks,
-john
thanks,
-john
