Did an Exeperiment
hobbyheater
Ran a small experiment this morning.
Our heat storage tank holds 1,260 us gallons the hot water tap was run at a flow rate of 1.3 us gallons per hour for 1 hour and in that hour the storage temperature of the tank dropped from 168 degrees to 161 degrees,roughly a consumption of 80,000 BTU'S per hour for 80 gallons of hot water or 1,000 BTU,S for one gallon of hot water!
The calculation could be gallons per hour x delta-T x 8.34.
1.3 gpm x 60 x (165-50) x 8.34 = 74,840 btuh. The rest of the btu consumption likely would be plumbing and tank losses.
Reactions: hobbyheater
