Did I just waste my time?
Flame On Posted By Flame On, Jul 31, 2013 at 11:45 PM
Thread Status:
  1. Flame On
    Flame On
    Member 2.
    NULL
    Sep 25, 2008
    58
    17
    Loc:
    Southeast PA
    I have four maples out back that occasionally drop branches. I cut up a few big ones today and stacked the sticks for kindling. I feel like I've done this before and the stuff never really dried out. The smallest pieces are just sticks and the bigger pieces run to maybe 3 inches.
    Should I split the bigger pieces?
    I like to have small stuff to get restarted and I've had a lot of luck with scrounged sticks in the past. I didn't want to waste the wood, but I feel like maple branches never really dry out.
    Thoughts?
  2. NortheastAl
    NortheastAl
    Minister of Fire 2.
    NULL
    Dec 30, 2012
    676
    389
    Loc:
    Putnam, NY
    Cut them to size, 16" or whatever you use. Split the 3" or larger. They will dry out.
  3. bogydave
    bogydave
    Minister of Fire 2.
    NULL
    Dec 4, 2009
    8,426
    3,446
    Loc:
    So Cent ALASKA
    Not a waste of time at all.
    Very little waste & "It's all BTUs" :)
    +1 for splitting the 3" stuff if it's gonna be kindling.
  4. oldspark
    oldspark
    Guest 2.
    NULL
    It does seem like it takes forever for 1 or 2 inch rounds to dry so I never get in a hurry to burn them, they will dry but give them an extra year or so.
    Applesister likes this.
  5. Ram 1500 with an axe...
    Minister of Fire 2.
    NULL
    Mar 26, 2013
    2,327
    670
    Loc:
    New Jersey
    I split one that was 2-3 in the other nite, it measured in the 28%, while my split and stacked from same tree is at 17%, so I said to myself, I'm not burning this pile this year. So I say yes, split them if you want to burn them, they must hold more water. Although mine are in a shady area so that could be a reason why so high in MC too...
  6. oldspark
    oldspark
    Guest 2.
    NULL
    Forgot to mention that those rounds dry from the ends so shorter is better, big difference in drying times between a 18 inch and a 12 inch round.
  7. PapaDave
    PapaDave
    Minister of Fire 2.
    NULL
    Feb 23, 2008
    5,740
    2,222
    Loc:
    Northern MI - in the mitten
    They'll dry...if given enough time.
    How soon were you trying to burn 'em?
    That small stuff goes on the stack just like everything else, and stays there until that stack is ready to burn, which is between 2-3 years. They may dry before that, but I don't need 'em.
    Applesister and ScotO like this.
  8. Flame On
    Flame On
    Member 2.
    NULL
    Sep 25, 2008
    58
    17
    Loc:
    Southeast PA
    I'd like to be able to use the stuff this winter, but I know it won't be ready. It just seems ridiculous that tiny pieces of maple take the same amount of time as oak! I only have a small lot, so I can't get more than 2 years ahead.
    Now that I'm really thinking about it, I had a problem with a small soft maple I took down at my dad's place. After a year the stuff was bubbling out the ends when I put it in the stove.
    We'll have to see what happens. I can always take the kids out on "stick patrol" when I need to refill the kindling bucket. :)
  9. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    I doubt then that it was soft maple. I can cut a soft maple and just leave the tree for a year or two and the whole thing will be dry enough to burn. I know of no other tree that will dry like that. Soft maple also can be cut and burned 6 months later and is perhaps the easiest wood there is to split.
    As for the rounds, there is no way I'd split a stick that is only 3". In addition, there is no way I will use rounds for starting a fire. Why make it difficult? Use only splits for building fires and life gets easier.
    amateur cutter, Paulywalnut and ScotO like this.
  10. Ram 1500 with an axe...
    Minister of Fire 2.
    NULL
    Mar 26, 2013
    2,327
    670
    Loc:
    New Jersey
    I say if your little rounds are wet,and you need them, then split them....
  11. MrWhoopee
    MrWhoopee
    Minister of Fire 2.
    NULL
    Sep 27, 2011
    600
    346
    Loc:
    Shingletown, Northern California (elev. 4000 ft.)
    +1
    Solid rounds are for extended burn time, splits light much more easily
  12. red oak
    red oak
    Minister of Fire 2.
    NULL
    Sep 7, 2011
    1,263
    772
    Loc:
    northwest Virginia
    Agreed - 5-6" is usually my cutoff, sometimes a bit larger if difficult to split. Throw those maple rounds in on a bed of coals and they'll do fine. And a 3" round does not need to be in your stack for years before you burn it. It will sizzle a little, but I've burned maple rounds of that size many times. As for the kindling, that is also a job I let my kids do, gather up a few containers of sticks it's a pretty simple job. Bark works also if it's dried out. I fill a few large bins in August or September and that's my supply for the winter.
    ScotO likes this.
  13. ScotO
    ScotO
    Guest 2.
    NULL
    When cutting down trees, I save everything 2" and up.....those smaller pieces do good at getting morning start-up fires going. I don't split anything smaller than 5", as was already stated they may sizzle for a couple minutes in the stove (yes, even after 2-3 years if they are a good hardwood), that goes to show that non-split wood does not readily give up it's moisture as split wood does.....
    That small amount of moisture coming out of a 2-3 year old 3" round of wood isn't going to cause you any problems.....
  14. oldspark
    oldspark
    Guest 2.
    NULL
    Scotty thats those multiple rows doing that do ya, my single row rounds dont sizzle.:)
  15. ScotO
    ScotO
    Guest 2.
    NULL
    if you say so Sparky. Funny thing is, the rounds are mostly stacked on the ousted perimeter of my stack! They get the most air!
  16. Paulywalnut
    Paulywalnut
    Minister of Fire 2.
    NULL
    Nov 29, 2012
    2,574
    1,095
    Loc:
    Kennett Square, PA
    I do split small oak rounds only. They can stay moist for years.
    Definately not a waste of time getting kindling and starter wood ready.;)
  17. PapaDave
    PapaDave
    Minister of Fire 2.
    NULL
    Feb 23, 2008
    5,740
    2,222
    Loc:
    I'll amend my previous reply here......Depending on how much kindling I have, my mood, how much small stuff there is, and a host of other factors, I may split and I may not split the small stuff.
    I don't however, sweat the small stuff.:cool:
    This year, I have a few boxes of kindling made from slab wood and strips from the shop. There's a ton more to be made in the same manner.
    There are also so many little branches in the woods, it's not really an issue if I don't split the small stuff. Pine, and Maple make up the majority of that. It's everywhere.
    If it weren't for the ticks............
  18. peakbagger
    peakbagger
    Minister of Fire 2.
    NULL
    Jul 11, 2008
    2,819
    620
    Loc:
    Northern NH
    When I am cutting birch on my brothers property I have to try to cut as small as possible so he thinks I am getting full use of the wood. I usually run the chain saw along the length of the trunk and the major branches after I have trimmed off the small stuff. It dries a lot quicker and unlike most birch doesnt start rotting immediately if uncut or split.
  19. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    OMG!!!! Burning that pine might make hair start to grow in the palms of your hands.....or worse. ;)
    amateur cutter and PapaDave like this.
  20. PapaDave
    PapaDave
    Minister of Fire 2.
    NULL
    Feb 23, 2008
    5,740
    2,222
    Loc:
    Evil Pine.
    My brother still won't burn it.
    But, he won't dry it either, so there's that.>>
  21. oldspark
    oldspark
    Guest 2.
    NULL
    Just having a little fun with yu, but the inside end wont get much, not sure how long I leave some of my rounds but green cut Mulberry and White Ash 4 or 5 inch rounds stay heavy forever it seems like.
    ScotO likes this.
  22. ScotO
    ScotO
    Guest 2.
    NULL
    I know you're busting me, brother...;)
    The small oak rounds seem to be the worst for me.......no matter how long you let them season, they always have a little sizzle to them.
    Backwoods Savage likes this.
  23. Applesister
    Applesister
    Minister of Fire 2.
    NULL
    Dec 5, 2012
    2,483
    959
    Loc:
    Upstate NY
    A 3" round of Ironwood could be 70 years old whereas a 3" round of poplar could be 4-5 years old. Beech hickory and Ironwood living in the understory is dense heavy stuff. I have some saplings that may push the 3 year drying time.
    I never actually thought about all this.
    If I come to stuff that doesnt burn I just restack it in another drying pile. Theres always next year, God willing. And I save everything. I cut sticks right down to 1/2" rounds.
    It might be a waste of time....
    But apple prunings and pear and plum and peach gets treated like gold.
  24. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    Right. Split them if you can, cut short if you can't.
  25. oldspark
    oldspark
    Guest 2.
    NULL
    Well I like rounds for the dead of winter but I hate sizzlers so the rounds get extra time in the stack.
    ScotO and PapaDave like this.
Thread Status:
