    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. MCPO Minister of Fire
    .......when I set the feed rate below #2. It seems the flame is just too low and does not put out enough heat . I would think the exhaust sensor probe (ESP) is sensing the lower heat output and turning the blower off..
    Can someone confirm this and is this normal?
    I was under the impression the fan would operate at the #1 setting or at least at #1.5.
    I`m an electrician and getting it to run at any temperature wouldn`t be difficult but maybe it will work fine as it is.
    John
    #1
    Helpful Sponsor Ads!
  2. rayttt Member
    poconos pa
    my p38 does the same.. the distribution fan will come on when every 10 to 15 minutes for about 4 to 5 mins and shut off again.Im assuming there just not enough heat to keep it running and itwould end up blowing cold air.
  3. MCPO Minister of Fire
    Thanks for the quick reply rayttt.
    John
Thread Status:
