Hello, everybody. Just installed a woodstove, ran the stovepipe into my masonry chimney, and have been using it for the last two days. The draft is great and we're all very toasty. I do not, however, have a chimney cap, so I made my own out of a couple of sheets of stainless steel and a steel frame.
Here's my question: exactly how high should this cap stand over the top of the chimney?
A complication: The chimney has three flues in it but I'm only using one. They all stop 6 feet shy of the chimney top, which means that that the draft runs up my active 8" flue and into a 16"x24" stack, then 6 more feet into the open.
Here's what I read in Domestic Engineering and the Journal of Mechanical Contracting, v. 98, in an article about chimneys: "The opening beneath the cap should be as large as the area of the flue. This area should be provided on each side."
So... to ensure that I don't screw up my draft... Does this mean the cap need to stand 16" above the chimney, so that I get a 16"x24" opening under both of the cap's long sides? That seems crazy to me. If it stands a measly (and more doable) 4" over the top, the total area would be equivalent to the area of the chimney. Is that enough?
Sorry for this lengthy question, I'm sure there's a simple answer...
