i finally hooked up a sidearm to the hot water heater, it didnt come with any instructions, but i put a tee in my drain valve connected that to bottom of sidearm, put a tee in the pressure relief valve outlet hooked to that from top of sidearm, is it neccesary to install coin vent, if so could i drill and tap the tee on top, also do these ever overheat the hot water heaters thanks for any info
