Do you need to sweep chimney for yearly cleaning?
md2002
362
United States
Hello,
I was going to buy a chimney sweeper and sweep the steel chimney for the pellet stove. My father in law tells me with a pellet stove there is no creosote so no need to sweep. I do everything else, but should I bother doing a chimney sweep?
Thanks
Mike
Should clean the vent pipe at least once a year. Over time, ash and creosote can slowly build up blocking the vent which will lead to a whole mess of problems for you and your stove.
Reactions: will711
Hello,
Thanks
Mike
If you are talking about your pipe, yes, you need to clean it every year. I just had my dealer come out and clean both my pipes at a cost of $232.00
There shouldn't be any creosote, but there will be some ash clean it out, the stove will be happier:)
Reactions: imacman and Defiant
Absolutely clean it, should be done after every season, some of us do it a couple of times:cool:
I brush the pipe after every ton (when cleaning the burn area). I break down everything, sweep, and leaf blow in the spring when closing the stove. In between I just empty the ash pan
