does outdoor temp affect performance
aaron12984 Posted By aaron12984, Oct 24, 2013 at 8:28 PM
Thread Status:
  1. aaron12984
    aaron12984
    New Member 2.
    NULL
    Oct 24, 2013
    4
    0
    Loc:
    ohio
    I bought a house in july and I started fixing up the old old wood burner in the basement. Its a gravity flow deal. The old guy who owned the home hasnt used it for 10 years. I spent a lot of time cleaning it up and making it functional again. New gaskets new ducting cleaned the chimney.
    I burnt some small stuff in it to test it. And everything functions great.
    Well we had some cool evenings high 40s and low 50s and ive been racking my brain. As to why it wasnt heating the house more than 2 or 3 degrees.
    tonight I built a fire in it. 37 outside and its heating like crazy. The burner has physically heated up better. From 60 in the house to 70 in an hour. I cant believe it.
    2 changes happened tonight. I put a flue damper in and after it warmed I closed it about 1/2 and the temp outside is much lower
    my question is does out side temp effect how a wood burner functions?
  2. HotCoals
    HotCoals
    Minister of Fire 2.
    NULL
    Oct 27, 2010
    3,429
    299
    Loc:
    Rochester,Ny.
    Yes it does.
    Way more draft when cold out.
    Temp differential thing..
    Good to hear it's now working for ya!
  3. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    It does make a difference in the draft, but I must say I wouldn't expect it to be that dramatic. But there are so many variables and the new damper is a wild card in how it affected things.
  4. PSYS
    PSYS
    Member 2.
    NULL
    Sep 26, 2013
    140
    60
    Loc:
    WISCONSIN
    I'm curious, as well.
    I kinda wish we didn't have the new damper variable tossed into the mix. It would've been interesting to see how the cooler outside air temp affected performance on its own...?
  5. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    The inside/outside differential will affect the initial draft and how well the fire starts, etc., but once a nice hot fire is established, it shouldn't make that much difference anymore since the heat of the fire takes over.
  6. HotCoals
    HotCoals
    Minister of Fire 2.
    NULL
    Oct 27, 2010
    3,429
    299
    Loc:
    Rochester,Ny.
    Well if the damper is open I doubt it is affecting much.
  7. aaron12984
    aaron12984
    New Member 2.
    NULL
    Oct 24, 2013
    4
    0
    Loc:
    ohio
    The damper is half closed at the moment.
    I wonder if its my wood. Im using the same wood but it has been seasoning in my basement with a fan blowing on it as well.
    its nice and toasty in here. My only goal with the wood burner is to cut down my oil consumption.
    at this point I dont so much care so mich why but that it works. I spent a lot of time cutting wood and fixing up the furnace
  8. HotCoals
    HotCoals
    Minister of Fire 2.
    NULL
    Oct 27, 2010
    3,429
    299
    Loc:
    Rochester,Ny.
    Hot things move to colder things faster then warmer things.
    Thermodynamic Rocket Science it's called! lol
  9. Sprinter
    Sprinter
    Minister of Fire 2.
    NULL
    Jul 1, 2012
    2,739
    599
    Loc:
    SW Washington
    Nicely put...
  10. HotCoals
    HotCoals
    Minister of Fire 2.
    NULL
    Oct 27, 2010
    3,429
    299
    Loc:
    Rochester,Ny.
    I try! lol Cheers!
  11. aaron12984
    aaron12984
    New Member 2.
    NULL
    Oct 24, 2013
    4
    0
    Loc:
    ohio
    Going to bed now. 31 outside and a sweaty 74 inside.
    I cant wait for my order of 1 year seasoned locust to come in. I am ready now. For once one of my crazy ideas might just pan out!
  12. HotCoals
    HotCoals
    Minister of Fire 2.
    NULL
    Oct 27, 2010
    3,429
    299
    Loc:
    Rochester,Ny.
    Great wood choice!
  13. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    Welcome to the forum Aaron.
    For sure that is a poor way of trying to dry wood. Try getting into the habit of being no less than 1 year old wood and that stacked outside in the wind. Top cover it if you feel the need but we don't top cover until early winter. Better yet is the 3 year plan. That is, always be 3 years ahead on your wood pile and you will solve over 90% of wood burning problems. It works.
    And for sure the temperature differential between indoors and outdoors will make a big difference on how you run the stove and how well the wood burns.
  14. aaron12984
    aaron12984
    New Member 2.
    NULL
    Oct 24, 2013
    4
    0
    Loc:
    ohio
    I know it is.
    I havent had the house and wood burner a year yet so I havent had time to season wood. I ordered wood thats said to be 2 year seasoned. So that should help.
  15. blades
    blades
    Minister of Fire 2.
    NULL
    Nov 23, 2008
    2,395
    640
    Loc:
    WI, Milw
    Ask them when it was split. If it was split just in the last few mo./wks it ain't season properly. Get a moisture meter most of box store home repair places carry them now for under $50,worth the investment. Take a split they bring respilt it down the middle and check the inside face with meter. 20% or less good to go, 20-25% marginal, above that , well your choice, but not usable this season.
Thread Status:
