Does This Sound Like Excessive Ceiling Clearance?
drewboy
185
Lakes Region, NH
I did do my homework and went way back and searched the site and the NFPA Install guidelines and I question why the tag on the back of my stove
calls for a minimum 59" clearance from stove top to ceiling - This seems excessive even when I went back through all the clearance posts...
As the stove sits on my hearth I have 56" ... There is nothing in the actual install manual that states 59", only the tag on the stove which I realize
probably trumps all else, but 56" seems like a very reasonable space. And yes it is EPA cert. on the tag and new as of last season...
Any thoughts - I would appreciate them,
Rob
Well, your house is not gonna burn down....if that is the question! In fact, I doubt the ceiling will be more than lukewarm.
Ceiling clearances are usually larger than the other ones for a couple reasons:
1. Heat rises
2. Most stoves have a flame path which puts the hottest part of the fire toward the top of the stove......
3. Stoves are tested in a black painted booth.......and sometimes tested for alcoves (walled in sides).
Well I kinda figured it was fine but sometimes I spend way to much time on this forum and I start feeling that paranoia about my install not being
perfect...I get the general feeling that you should be a stickler for clearances and safety so that's why I questioned that #.
Oh, only my wife thinks I spend too much time on Hearth.com ;-P
Thanks
