    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Seasoned Oak Minister of Fire
    Eastern Central PA
    I just bought an infrared laser temp guage. Quite a neat little tool . Whats amazing is how far off my mechanical rutland temp guages are. My 4 year old rutland is reading too low from 50 to 60 degrees . Go another one about 3 months ago and that one is a whopping 100 degrees too low. Im going to see if here is some way i can adjust the rutland gauges.
    I noticed some of the guages at the store were already reading 150-200 degrees in a room temp store so i got the one that was reading about 75.
    #1
    Helpful Sponsor Ads!
  2. lopiliberty Minister of Fire
    Mineral County, WV
    I had one of those rutland thermometers and when I bought the liberty my dealer gave me a condar. So I thought I would test them both out side by side to see with one was better. Turned out if I remember correctly the rutland was reading 100 to 150 degrees lower than the condar, so now the rutland is somewhere in the landfill.
  3. corey21 Minister of Fire
    Soutwest VA
    Yeah i found that that out myself recently now i am going by just my probe in the flue. Also using more common since after that going to get an ir gun.
  4. WhitePine Feeling the Heat
    My Condar magnetic (ChimGuard) model is spot on according to our IR thermometer, as least as far as can be told considering the "resolution" of the Condar's markings. ;lol
    Bottom line, I trust my Condar.
    The Rutlands sound horrible. I'm glad I don't have one.
    lopiliberty likes this.
  5. BrowningBAR Minister of Fire
    Doylestown, PA
    Yep. I have three stove top thermometers. Each by a different brand. Each one is off by 50-200 degrees.
    I just use them as general estimates. The infrared is used if I want a more exact reading.
  6. Mad Tom Member
    Vermont
    I think both brands are junk. Up here the Condar is about 20 bucks and lasts a year for me. By the time the next season comes it is all messed up. They are not exactly an accurate scientific instrument,Just look how cheaply built they are. I use an IR meter now .
  7. David Tackett Member
    Waynesburg, Kentucky
    Nah, they are crap. Harbor Freight has an infrared thermometer $59 on sale right now for 19 bucks. Goes up to 900 degrees. Think I will get one. The reviews look good on it.
  8. Treacherous Minister of Fire
    WA state
    It works well. I just changed the 9V battery for the first time today. I've had it a couple years now IIRC.
    David Tackett likes this.
  9. dave_376 New Member
    central Ct
    my stove top thermometer is off by 100F according to my new Harbor Freight IR.
  10. BrotherBart He Who Moderates
    Northern Virginia
    I have to wonder why we think the IR thermos waving in our hand are more accurate. Just saying...
    tfdchief and jeff_t like this.
  11. Seasoned Oak Minister of Fire
    Eastern Central PA
    Mostly cuz when we point them at a known temp, say a body part, they are accurate. I took it outside today thermometer said 41 IR said 41 . Indoor digital thermometer said 78 Ir said 79. Pretty close.
  12. DexterDay Minister of Fire
    NE Ohio
    Condar, Rutland, Meeco's are just a few that I have.. All are off and all are cheaply made.
    Get a Tel-Tru and never look back :)
  13. jjs777_fzr Feeling the Heat
    NorthShore, MA USA
    pointed at a pot of water on the stove - begins to boil at the Centech IR gun reading of 211-212F - whether its accurate at higher temps I don't know - I suppose one of us could check against Mercury with a boiling point of 674F.
    jeff_t and BrotherBart like this.
  14. jjs777_fzr Feeling the Heat
    NorthShore, MA USA
    great - tel-tru - yet another gadget I see in my future to check out - sounds well made
  15. Seasoned Oak Minister of Fire
    Eastern Central PA
    Those crappy rutland guages are $15 . I only paid $24 for this IR Laser handheld guage from harbor freight. A small difference for a way more capable product. Range is -4 to 950+F. I also wanted the IR guage for other reasons like determining where the cold spots in walls are for insulation purposes.
  16. Huntindog1 Minister of Fire
    South Central Indiana
    Here is one with free shipping from the same person I bought mine from. Its works great for me. He had fast shipping.
    It goes to 1022F.
    Best one I could find for least money that goes to that high of temp, its has the laser pointer also, so you know the spot its taking the temp from.
    $24.56 free shipping
    Neiko Infrared Laser Aim Thermometer Gun, Non-Contact, Up to 1022F
    http://www.amazon.com/Neiko-Infrare...t/dp/B005K1N7F4/ref=?ie=UTF8&m=A10QFO4IXVZNRN
    Specifications
    Temperature range: -30 to 550C (-22 to 1022F)
    Accuracy: +/- 3C or +/-3% of reading -30 to 0C (-22 to 32F)
    +/- 2C or +/-2% of reading 0 to 100C (32 to 212F)
    +/- 3C or +/-3% of reading > 100C (212F)
    Display spot size: 10:1
    Repeatability: 1% of reading or +/- 1C
    Response Time: 500ms
    Spectral Response: 8-14um
    Emissivity: 0.1 - 1.0 adjustable
    Relative Humidity: 10-95% RH non-condensing
    Operating Temperature: 0 to 60C (32 to 140F)
    Storage Temperature: -20 to 60C (-4 to 140F) without battery
    Power Supply: 9V 6F22 battery
    Battery Life: 12 hours
    Product Size: 165 x 80 x 41mm
    Product Weight: 155g (without battery)
  17. corey21 Minister of Fire
    Soutwest VA
    I wonder the same thing.
  18. Huntindog1 Minister of Fire
    Mechanical spring type can wear from repeated heating and cooling so as they go out of calibration.
    Digital technology has no moving parts expansion or contraction and is calibrated and has specifications that were tested to be with in specs.
    Less likely to go out of specs.
    You can pay more money and get IR Therm that are more accurate.
  19. Backwoods Savage Minister of Fire
    Michigan
    We never used a stove thermometer until we bought the Fireview. Now I'd hate to be without one. We also have one on the flue.
    A Condar came with the stove and this is what got us started. We then purchased a Rutland at the hardware and were given either one or 2 more Rutlands. We also bought an IR and checked them. We ended up throwing all the Rulands away and bought another Condar for the flue.
    As for them lasting, our 2 are now into their 6th winter and doing just fine.
  20. Seasoned Oak Minister of Fire
    Eastern Central PA
    My 5 years old rutland is more accurate than the one i just bought a few months ago. The newest one is off by 100 Deg. I did notice at the store (TCS)some of the rutland gauges were reading 200 degrees at room temp. THe one i got was reading about 75 deg and its still off by 100.
  21. Prof Member
    Western PA
    Both of my Condars are about 100 F cooler than my IR thermometer.
  22. wkpoor Minister of Fire
    Amanda, OH
    I know the Rutlands have a bad rap on this forum but I have 3 that are all at least 10yrs old. I compare them often to my IR. Not saying either is accurate but they all agree very closely.
  23. DexterDay Minister of Fire
    NE Ohio
    Have not seen you in awhile. Just looked at your Signature??
    Another Elm!! Nice.......
  24. GrampaDennis New Member
    Central Maine
    Tonight, I ordered a few items from Rockford Chimney Supply (They advertise here, and support the forum.) One of them was a Condar Woodsaver stovepipe thermometer. If I hadn't been reading this forum, I probably would have bought a Rutland locally.
    I've burned wood for over 30 years without a thermometer on the wood furnace, on the stove, or on the stovepipe. However, in making a new start with a modern EPA stove, I decided to give one a try.
    I also looked at the IR thermometers at Harbor Freight. There were 3 reasons why I didn't go that route: (1) There were some bad reviews, saying the IR thermometers had crapped out. (2) The IR thermometer would be more bother to use. (3) I can't picture the Mrs using an IR thermometer, but I think she might watch the stovepipe thermometer.
  25. OhioBurner© Minister of Fire
    Central Ohio
    Any other inexpensive options for continuous temp display? I like my IR, and am pretty much forced to use it on the insert, but having 3 stoves on 2 different floors... well its a pain having to get the thermometer each time. Especially when you go down to the basement and forget it. Is there any other accurate types of thermometers, perhaps electronic, that arent too expensive?
