Door Gasket
Either glue it back on or replace it.
Bigg_Redd said:
The door gasket on my 2.5 year old PE Spectrum Classic has come lose. What should I do?
If you can re cement it you can try it but it might not work well. The other option is to pull it out and clean the channel with a wire brush. After the wire brush use cement and a new gasket then shut the door for a couple of hours to dry. The fire her up again and burn baby burn :)
Pete
Yes, a real head scratcher. Is it lose or loose?
No. Try again.
I've been burning for the last couple hours and everything seems fine and normal, but I still wonder if I did it right. . . .
Take the stove to the dealer so they can inspect it and critique your work.
