Door Glass Cleaning: Anyone thought of...
Swamp Fox Posted By Swamp Fox, Oct 24, 2006 at 7:37 PM
Thread Status:
  1. Swamp Fox
    Swamp Fox
    Member 2.
    NULL
    Jan 12, 2006
    92
    11
    Went out today to buy a few things and bought a bottle of "FAST ORANGE" hand cleaner. Had some time to kill and got to reading the back of the bottle and read that it is petroleum sovent free, is a citrus cleaner, and removes the following: "...toughest dirt, grease, grime, soils, resins, printer's ink, paint, glue, rubber cement, gasket and tile cements." It comes with or without pumice. I was wondering if anybody has tried any of this stuff (or the Gojo brand) to clean their stove door glass. I plan on giving it a try the next time I clean my glass. Any thoughts?
  2. Jfigliuolo
    Jfigliuolo
    New Member 2.
    NULL
    Nov 28, 2005
    82
    0
    use a damp cloth dipped in ashes. cheap and it works.
  3. suematteva
    suematteva
    New Member 2.
    NULL
    May 25, 2006
    605
    0
    Loc:
    Rutland, VT//Southern Quebec
    we use white vinegar and water it works also.
  4. AKFireMan
    AKFireMan
    New Member 2.
    NULL
    Jan 19, 2006
    29
    0
    Loc:
    Fairbanks, Alaska
    Be careful using the stuff with the pumice. That stuff is very abrasive and can etch your ceramic. I use it at work alot ( without pumice) and it is a great general purpose cleaner. We tried to clean regular glass with it and it tends to streak alot. .02 worth
    Ron
  5. junksta
    junksta
    New Member 2.
    NULL
    Oct 13, 2006
    44
    0
    Loc:
    Pinedale, AZ Elev. 6400'
    It seems like anything with orange citrus works for me, tried a couple of citrus products you find at the dollar store and they work great.
  6. GVA
    GVA
    Minister of Fire 2.
    NULL
    Sep 4, 2006
    2,140
    0
    Loc:
    Waxhaw, NC... Formerly North shore Mass
    Well the common denominator in all those citus products is "citric acid" and a little scent for those faint at heart.
    An old trick is when cleaning your grates for your barbque is to take a couple of those packs of cool-aid and add them to a bucket of hot water (I mean hot) soak the grates for about a 1/2 hour then hose them off, hardley any work......... But for the ceramic glass I'll stick to windex ;-)
  7. hilly
    hilly
    Feeling the Heat 2.
    NULL
    May 28, 2006
    308
    15
    Loc:
    Vancouver Island, Canada
    Am I the only one that just uses a damp rag or am I lucky I've got a clean burning stove with dry wood?
  8. greenergrass
    greenergrass
    New Member 2.
    NULL
    Sep 28, 2006
    24
    0
    I have found that if I burn between 500 to 600 surface temp, whatever is on the glass just comes off. After one season of burning I might clean the glass 3 or 4 times.
  9. smirnov3
    smirnov3
    Feeling the Heat 2.
    NULL
    Feb 7, 2006
    439
    1
    Loc:
    Eastern Ma
    With my pellet stove (accentra insert), a damp rag seems to do the job (I figured that if damp ashes do a good job of cleaning the glass, then why not use the ashes already stuck to the glass?)
    If you do use a cleaner liquid, be carefull that it doesn't contain soap (some generic / cheap cleaners do) - it will streak your glass unless you wash it off with water (double your work for no good reason)
  10. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    63,805
    8,303
    Loc:
    South Puget Sound, WA
    Put your stove type in the signature block please so that others know what you're burning. The stove type can have a big influence on how clean the glass stays and how often one cleans it.
  11. tradergordo
    tradergordo
    Minister of Fire 2.
    NULL
    May 31, 2006
    811
    3
    Loc:
    Phoenixville, PA
    As already mentioned in the last thread about cleaning stove glass - yes, this stuff works great!
    p.s. I too have found that I get no buildup at all when I burn properly seasoned wood and don't let the wood touch the glass. Then again, not all of my wood is properly seasoned.
Thread Status:
