    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Dovre 400
Post in 'It's a Gas!' started by Niq, Sep 10, 2012.
  1. Niq New Member
    I was just given a Dovre 400 direct vent lp gas stove.
    I was wondering if it was possible to put a thermostat on it.
    #1
    Helpful Sponsor Ads!
  2. A1Stoves.com Feeling the Heat
    Northern CA
    yes, it uses the basic robertshaw valve (if memory serves) connect 18g 2 strand wire to the top and bottom terminal of the valve.
    if it has the sit valve, wiring is the same.
    dave
  3. Niq New Member
    You just made my day Dave.
    Thanks!
  4. DAKSY Super Moderator
    The better description of the connections would be the two terminals designated TH & TH-TP (or TP-TH), where TH can be thought of as THermostat...Just sayin...Also, make sure you purchase a Millivolt (mV) thermostat...
  5. A1Stoves.com Feeling the Heat
    Northern CA
  6. Bioburner Minister of Fire
    West central Mn
    Most certainly. I have one that I added a after market remote(heat n glo) that has thermostat and timer etc. Great stove. My CL buy of the year for $100 in enamel Blue with venting. Great backup for my pellet stoves as it needs no power or for additional heat boost when the thermometer goes way south. Well worth putting a fan on it too.
