I seem to be having a problem with downdraft/negative pressure in my fireplace. I had the chimney cleaned on Saturday and sat down for a nice fire that night. First I had a little trouble getting it going, but then realized that smoke was backing up in my basement. It was actually coming out of furnace exhaust pipe in the crawl space. I opened a window downstairs and cracked a window in the living room (where the fireplace is) and it helped a little. When the furnace is on and the fan is blowing, the smoke does not back up in the basement. The chimney sweep said they cleaned both pipes and that he tested the draw on the furnace pipe and it was working. The smoke doesn’t come back out of the fireplace, which means that it must be pulling up the chimney and then back down into the basement. The house was built in 1950, so you know it isn’t tight. Any ideas on how to correct the problem. Do you think the HVAC guys can help? I had a new furnace installed about 2 years ago and I wonder if it was installed incorrectly. I have caps on the chimney and it appears to be the proper height. My neighbor has a huge weeping pine tree that could be contributing to the downdraft, but to see smoke coming out of a pipe downstairs seems very odd. We always had a little smell for about a day or so after having a fire, but never smoke in the house. Any ideas? Thanks for your help.
