    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Pallet Pete Minister of Fire
    Ovid MI
    Agreed !
    Pete
    #26
    Helpful Sponsor Ads!
    corey21 likes this.
  2. corey21 Minister of Fire
    Soutwest VA
    Sounds like a plan ill report back to this thread tonight or in morning with the results.
    I covered the wood out on my car port and bring in a wheel barrel load of my other wood not oak.
    Pallet Pete likes this.
  3. WellSeasoned Minister of Fire
    Eastern Pa
    Sounds good.
  4. Huntindog1 Minister of Fire
    South Central Indiana
    Corey,
    Hows the front glass doing ,does it get dirty?
    Some on this board report having to clean fairly regular, some clean the window rarely , some report all they ever get is a light coating the can brush off.
    Guess all depends on the wood and how your operating the stove.
    The draw of the flue dictates how much air is being sucked thru the stove, you can control it some with the primary air control but the secondaries are wide open so as that as the flue heats up the suction is higher. Some people tweak their stove operation with a manual flue damper. Some have reported getting their stove top temps to heat up hotter by closing the manual flue damper 1/4 turn as that indicates too much air is being sucked thru the stove by an unusually strong draft causing heat to be wasted up the flue.
  5. corey21 Minister of Fire
    Soutwest VA
    My glass gets dirty when burning the oak i think oak is the main issue.
  6. corey21 Minister of Fire
    Soutwest VA
    jeez!!
    Did not take long at all to hit 400 stove top looks like the bowls of hell at moment.
    Also went by my probe.
    Watching the mag like a hawk right now.
  7. corey21 Minister of Fire
    Soutwest VA
    Had to crank the blower up to calm her down just about had a pause and reflect moment.
  8. Pallet Pete Minister of Fire
    Ovid MI
    Have you checked the door gaskets as well ? Put a dollar bill in the door and close it then pull if it slides out easily your doors need to be tightened. The size of splits also makes a big difference smaller splits equals more gas in the stove which equals too much gasifier your not careful. You can over fire it easy with small splits so mix some larger ones in if that is what was causing it.
    Pete
  9. Huntindog1 Minister of Fire
    Oak can take up to 3 years to season. That may be the issue.
  10. corey21 Minister of Fire
    Soutwest VA
    I just replace the gasket a week ago just had a good hot fire going last night.
  11. corey21 Minister of Fire
    Soutwest VA
    I think your right i was just hoping it would be ready that's all.
  12. Pallet Pete Minister of Fire
    Ovid MI
    Good stuff corey I figured it could not hurt to ask. You are well on your way to good burning.
    Pete
    corey21 likes this.
