Drying wood in the oven???
barrettdp Posted By barrettdp, Jan 18, 2011 at 4:25 AM
Thread Status:
  1. Dune
    Dune
    Minister of Fire 2.
    NULL
    Jan 14, 2008
    3,128
    273
    Loc:
    Commonwealth Of Massachussetts
    Use your woodstove as a de-humidifier. Stack as much firewood in the stove room as posible. Keep it a few feet from the stove. Buy a pallet of bio-bricks and burn them. There are many threads on bio-bricks. Use the search feature. Have patience with the wood. It will dry inside due to the heat and low humidity. A couple weeks or more. Never seen a turkey in the oven burst into flames.
  2. Battenkiller
    Battenkiller
    Minister of Fire 2.
    NULL
    Nov 26, 2009
    3,740
    19
    Loc:
    Just Outside the Blue Line
    We speak fluent glass here. Well, my wife does, I only dabble with the stuff... just because it's playing with fire and all. It's funny how often we hear that. I think I even remember my chemistry professor telling us that when we were studying crystal structure. We once bought some antique poured glass panels, and the guy was showing my wife how it was thicker at the bottom because it slowly "melted" over the years. How he knew which end was up when it was glazed into the window frame I'll never know.
    Of course, in this place, we have no problem getting it to flow at slightly higher than room temperature....
    [​IMG]
  3. jlove1974
    jlove1974
    Member 2.
    NULL
    Dec 8, 2010
    245
    0
    Loc:
    Piedmont of NC
    If you do this, make sure you use Hickory, Apple, or a similar wood. Put in oven at around 270 degrees.
    Wet wood thoroughly before putting into oven. Add desired white meat. Smoke til done ;)
  4. logger
    logger
    Minister of Fire 2.
    NULL
    Feb 28, 2009
    687
    69
    Loc:
    Pine Barrens, NJ
    Didn't get it. Ill send you one and see if that works, but my inbox is empty.
  5. Rachel Porter
    Rachel Porter
    New Member 2.
    NULL
    Nov 28, 2013
    1
    0
    Loc:
    Brooklyn, NY
    Wow, talk about unsolicited rudeness. I've been trying to figure out how to quickly dry firewood and so far, all the responses I have found have been: 1) "It needs to dry for a year" (I understand that is how you're SUPPOSED to do it, but this is obviously not what I am asking about) or 2) "What a stupid idea, city folk etc etc"
    I'd like to point out that in order to be a "city person" you must be resourceful, creative, and brave enough to try new things. City people do not do things a certain way just because that's how generations of family members have done them, and unlike some "country folk", are not incapable of imagining new ways to get things done. Before you're rude to someone who doesn't know how to start a fire (because there are, actually, higher callings than fire starting) try to have some compassion. It takes all kinds.
  6. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,842
    8,616
    Loc:
    South Puget Sound, WA
    Welcome Rachel. You are responding to a 2+ year old thread. This is a common topic which has many other threads on it. In an urban environment your best bet is going to be bring the wood indoors and if possible have a fan blow across it. Wood that has been in the house in boxes or rubbermaid containers will dry out considerably faster in a warm ventilated space. If you have a good axe or splitting maul, splitting the larger splits and rounds in half will accelerate their drying. I would not try using the oven to do this. If you can set up the wood as stacks with a fan blowing through them it will be fairly effective and safer.
    Here's another thread with some good tips on drying wood:
    http://www.hearth.com/talk/threads/uh-oh-wood-is-wetter-than-i-thought-advice.81238/
  7. Dave A.
    Dave A.
    Minister of Fire 2.
    NULL
    Mar 17, 2013
    614
    74
    Loc:
    SE PA
    300F sounds a little high to me. I'd try somewhere between 200 and 250 for an hour or so.
  8. Hogwildz
    Hogwildz
    Minister of Fire 2.
    NULL
    Nov 3, 2006
    8,021
    1,649
    Loc:
    Next to nuke plant Berwick, PA.
    If you go to Walmart, buy a few of their larges storage totes, and fill them with wood inside the stove room, they will dry well. You may have to watch for insects or not coming from the wood.
    Reload each tote as it is emptied and you will have a revolving supply of dry wood.
    I loaded 5 large totes in 2010 when I had a hernia op and was not very mobile.Worked very well.
  9. tsquini
    tsquini
    Minister of Fire 2.
    NULL
    Jan 8, 2009
    677
    244
    Loc:
    North Shore, MA
    Instead of baking logs why not just bake bread. Bread bakes at 400* and at the end you have something to eat.
    If I were to bake logs I would defiantly bast it every 30 min. Until the internal core temperature hit 180* . Then let I'd sit for 30 min before you split it against the grain. Then let it burn.
  10. My Oslo heats my home
    Minister of Fire 2.
    NULL
    Sep 20, 2010
    1,584
    165
    Loc:
    South Shore, MA
    As others have said, try trading for dry wood. There might be someone that is will to help you out.
    Pallets are another options, as well as bio bricks.
    Mixed options, putting in dried wood with a portion of unseasoned.
    And I like Hog's idea, I have done it too in a pinch. Place unseasoned wood near your stove and
    it will help dry it a bit more before burning.
  11. Woody Stover
    Woody Stover
    Minister of Fire 2.
    NULL
    Dec 25, 2010
    8,250
    2,334
    Loc:
    Southern IN
    I had pretty good luck a couple years ago, stacking wood that was split small in the house with a fan blowing on it. Took it from 25% to 20% in two weeks. If your stove is a non-cat, you might be able to go ahead and burn 25% wood and still get some heat off it....
  12. Big Dan
    Big Dan
    New Member 2.
    NULL
    Nov 25, 2013
    72
    10
    Loc:
    quahog Rhode island
    I would soak your wood in gas. remember to get the high-octane because the longer burn time.
  13. dmmoss51
    dmmoss51
    Feeling the Heat 2.
    NULL
    Oct 28, 2013
    355
    82
    Loc:
    Michigan
    I think if your goal is to have a nice little fire for ombiance during the holidays and you're just talking about a few splits drying wood this way will get you what you need.
    However, as pointed out before, for home heating purposes the quantities of wood needed would make this very inefficient.
  14. Tenn Dave
    Tenn Dave
    Minister of Fire 2.
    NULL
    Jun 6, 2013
    717
    292
    Loc:
    SE Tennessee and New Jersey Shore
    Make sure you season the wood liberally with plenty of salt and pepper. Another southern favorite is to deep fry it.
  15. dmmoss51
    dmmoss51
    Feeling the Heat 2.
    NULL
    Oct 28, 2013
    355
    82
    Loc:
    Michigan
    The problem is your wood needs to be completely dry before putting it in the oil or else there could be a dangerous boilover which can cause a fire. Only use your turkey frier to dry wood outside in a well ventilated area :p
    Big Dan likes this.
  16. Tenn Dave
    Tenn Dave
    Minister of Fire 2.
    NULL
    Jun 6, 2013
    717
    292
    Loc:
    point well taken..........
  17. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,842
    8,616
    Loc:
    and with that note, Good night, Gracie.
Thread Status:
