    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. kenstogie Member
    Albany (ish)
    I have a OAK of the below variety and would like to clean my exhaust venting
    Isn't there a way to open up that bottom of that T connector for cleaning??
    I pulled off the aluminum vent tape and cant really see how to take it apart??
    If there isn't why the he!! not??
    Oh and many thanks to those that have chimed in with my past questions and helped me with there knowledge, :)
    [IMG]
    [IMG]
    #1
    Helpful Sponsor Ads!
  2. jlupi Member
    hudson valley, ny
    twist and pull
  3. kenstogie Member
    Albany (ish)
    its that easy?? what sections separate??
  4. UMainah Member
    Bangor, ME
    The bottom end of that tee is actually a cap that you "twist and pull" off.
  5. kenstogie Member
    Albany (ish)
    thanks, i tried that but it seems stuck.
  6. pell it Member
    Rhode Island
    I use an oil filter wrench.
    kenstogie likes this.
  7. kenstogie Member
    Albany (ish)
    good idea especially since i have one.
  8. DV Member
    Southern MD
    Elbow grease
  9. P38X2 Minister of Fire
    Jaffrey, NH
    All of the above. Use 2 filter wrenches if you have em. Unless you have gorilla hands, it's hard to get a good grip on the pipe as you turn the cap. Might come right off, prob be a bit of a pain though.
  10. DV Member
    Southern MD
    or cleaning brush and leaf blower?
    P38X2 likes this.
  11. P38X2 Minister of Fire
    Jaffrey, NH
    Yeeessssss! :) Much more fun
  12. kenstogie Member
    Albany (ish)
    its the very bottom portion that protudes out about an inch or thereabouts, correct?
  13. DV Member
    Southern MD
    yes. righty tighty... lefty loosy. I say this from experiences of my own.
  14. pell it Member
    Rhode Island
    Yes and it will turn less than a quarter turn counterclockwise looking up from the floor.
  15. kenstogie Member
    Albany (ish)
    thats what i thought but doesnt budge but i will try my binford oil filter wrench ;)
  16. P38X2 Minister of Fire
    Jaffrey, NH
    If yer using a Binford, make sure you don't crush the pipe ;)
    Try using a little PB Blaster or something. Might help. Make sure you wipe it off before reassembling.
    SmokeyTheBear likes this.
  17. kenstogie Member
    Albany (ish)
    Roger P38x2. Will do. I have that stuff, I heard it's great but better if you let it soak a bit.
  18. SmokeyTheBear Minister of Fire
    Standish, ME
    If all else fails there is always the replace the tee method >>>>>>>>>>>>>>>> bear running for the woods >>>>>>>>>>>>>>
  19. kenstogie Member
    Albany (ish)
    i did finally get it, it didnt come apart in the spott i thought. i ended up using a "strap wrench" which is basically a nylon reinforced belt wedged in a handle.
