Durock
I've done it both ways with success.
I think if I was to do it again I'd put down the backer board and then coat it with Redgard, then lay the tile. This should give you the added stiffness of the backer board with the waterproofing and isolation of Redgard.
Reactions: bobdog2o02
As a contractor this is what i do in wet areas. I prefer hardi backer over durock for ease of cutting. I have a circular saw blade and table saw blade just for with hardibacker.
Thing is the tile association wants a minimum of 3/4" plywood under tiles, How does 5/8" OSB compare in stiffness? I am guessing not well. This can result in loose tiles, broken tiles and cracked grout seems. Just sayin.
All we know is tile over OSB. He didn't say anything about the thickness or support of the OSB.
Agreed. Standard subfloor is 5/8 and in my estimation, OSB is not as stiff as plywood, but I don't know that for sure.
standard here is 3/4 osb t&g and depending on manufacture can be much stiffer. also depends on floor joist framing, spacing and type, white wood, southern yellow pine, trusses, tgi. spacing 16 inch 19.2 or 24 on center. When I was on the east coast standard drywall was 3/8, moved here everything is 1/2. We need to be careful what assumptions we make. We are scattered all over the country.
Same here.
However, I've seen some reports lately of rotting Hardibacker in wet areas like showers. I'm not sure how accurate they are but it does make some sense since I believe Hardibacker contains wood fibers where Durock doesn't.
Anyway, on my last shower job I used Durock with Redgard over it.
Same here.
The durock has a label that says no wood or gypsum ingredients. It is a bugger to cut though. Not the straight cuts but things like notches around door jambs.
Hard I makes a backer "for wet locations" idk but I'd bet some hack installed the 1/4" stuff where it doesn't belong.
