    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Nutmeg Warrior New Member
    CT
    I just got burned on an "open-box" blower purchase on ebay (it was used, abused and doesn't work!). So now I am looking at new options and they're crazy expensive. $275 is a lot for two speed fan without a thermostat. Are there cheaper options out there? Is there some generic fan that I can use here? I'm guessing the holes for the flange mount just need to line up..?
    BTW, stove is a dutchwest 2462.
    #1
    Helpful Sponsor Ads!
  2. Shane Minister of Fire
    Casper Wyoming
    Check Grainger.
  3. webby3650 Minister of Fire
    southern Indiana
    The blower is pretty generic looking on the Dutchwest, you might do OK at Grainger. I've looked there in the past and found their blowers to be nearly the same price as the factory one.
    Just remember to block the convection holes on the bottom of the stove. I think the factory blower comes with these cover plates, but I can't remember for sure.
  4. Nutmeg Warrior New Member
    CT
    Thanks for the ideas. Grainger looks good but I guess they need to be wired up. They don't seem to come with plugs.
  5. Woody Stover Minister of Fire
    Southern IN
    I think I got mine on Amazon. I can't get it out right now, will do that shortly, and try to find out how much I paid. I'm sure it was a lot less than $275. My 2460 was back in the fireplace, which created a megaphone effect...pretty noisy in the same room with it. :mad: I think a quieter aftermarket blower might be the way to go...
  6. Nutmeg Warrior New Member
    CT
    Thanks Woody. I'm interested to know which model you're running.
  7. ernie Member
    Missouri
    We are a VC dealer and sell the blower on our parts store online for $229.00
    Www.hechlers.com
  8. Woody Stover Minister of Fire
    Southern IN
    I think this is the one I got; Can't find my purchase record for it. I'm pretty sure I paid less for it, though. I seached for the blower and saw some pics of a squirrel-cage type; Maybe that's for the newer models but you would think that if the stove has the same model number, the parts should be standard. :confused: Maybe that's a new, improved (quiet) fan that would fit old and new.
    This is the one I got:
    http://www.ebay.com/itm/0009973-Dut...od-Stoves-Factory-Original-9973-/151008664159
  9. Nutmeg Warrior New Member
    CT
    Thanks Woody, I've seen this listing before. Good to know that it's legit.
  10. Havendalefarm Member
    New Haven ,NY
    If your handy I am pretty sure you can get just the motor at Grainger. I could be wrong. When I thought ours was shot I just took it apart and cleaned it up and lubed the bearings and it has worked ever since. We don't use it that much though as it seems to do nothing but interfere with the already good air movement we get from the ceiling fan over our stove.
