EARTH STOVE 1000HT MANUAL
rustynut
377
mid mich
hi there,
ran across this stove at an auction this weekend and couldnt pass it up.
cleaned the door glass & brass........looking good
metal has a bit of rust but nothing a few minutes with the sand blaster
wont fix. couple of cans of that hi temp paint and we'll be looking good.
stove is a few years old with an inspection date of 1987. looked thru the lennox site for a manual with no luck. might be a bit too old ?
got it on its back right now so i cant get at the tag but i'm thinking that it had install instructions and more info.
would still like to get a manual for my $35 dollar jewel ?
got any ideas ?
thanks
rustynut
rare stove, only made in 1987!!! we dont even have a manual, so i doubt you'll find one... here is the parts list.
1000HT / 2000HT
Wood, Freestanding w/ Pedestal (1000HT) & Insert (2000HT), 6" Flue, Residential / Mobile Home, Non-EPA
ITEM NO DESCRIPTION
14M72 Door Assembly, Gold Glass, G3000 (door w/ concealed hinges)
G6000 Door Assembly, Cast Black, H0533 (handle included)
86-128 Gasket Kit, 3/4" Door (includes adhesive)
27M81 Gasket Kit, Glass
G2000-7 Glass, 9 1/2 x 15 3/4, Arched Ceram Pane (gasket not included)
10300 Handle Assembly, LB-102214 (does not fit brass doors. handles for brass doors are no longer
available)
85-11 Spring, Door Handle Coil
14M22 Blower, Room Air, Model 1000HT, 820 (includes Dial-A-Temp)
14440 Dial-A-Temp, Blower Speed Control, Model 1000HT (plugs into outlet then blower plugs into Dial-ATemp)
10050087 Knob, Rheostat, 02107, Model 2000HT - For 528 Rheostat (replaces 527 Knob)
528 Rheostat, Blower Speed Control, 02082, Model 2000HT
14M21 Stove Stat Kit, 18840, Model 1000HT (thermally activates blower)
907 Spring, Module Handle Coil, 00907
2047 Trim Set, 32" x 42" 2000HT Brass, 02047
14M76 Adapter, 6" Offset (for Insert model 2000HT)
14M67 Duct, Floor, 78-35, 5 1/4" square (for Freestanding model 1000HT)
70K99 Paint, Metallic Black, 12 oz Spray Can, 76-141MB (#6309)
FB-1 Firebrick, 9" x 4 1/2" x 1 1/4" Standard (order 9 if set is needed) *
FB-2 Firebrick, 9" x 4 1/2" x 1 1/4" Notched. (order 10 if set is needed) *
thanks for all the info
rn
Any pictures?
umm...
guess i should have took a couple of pics before i got started
door has been cleaned & polished with good results
got the stove disassembled now
going to give it a good cleaning/ sand blasting
then some paint
we'll see about some pics before i clean the metal
then maybe again after
rn
