Efficient storage tank layout
carbon neutral
306
S.E. Connecticut
What would be the most efficient set up for a heat storage tank(s) if I plan to use a wood boiler and solar heat? I would think the best solution would be to put the tanks in series and operate them as a cascade. The returning cold water would pass through the solar tank first then the wood boilers tank. Solar would tend to operate more efficiently at lower temperatures so I would think having a seperate tank from the wood boiler would be best?
Current thoughts on tank sizes would be 250 gallon tank for 160 ft/sq solar and 1300 gallon for EKO 40. Do these tank sizes sound about right?
Also during the summer months I plan on using the wood boilers tank for irrigation (solar alone should provide ample heat for DHW so I don't need the boilers tank), rain water from the roof will be directed to the tank and a sprinkler pump will be used to pump out the tank. Can anyone think of any issues I may have by filling and draining the tank on a daily basis?
I would definitely check into filtration of rain water prior to tanking it.
Will
My thoughts on filtration are to use gutter guards on the gutters, which keeps leaves, branches, and other large stuff out of the gutters. Then just before the tank have a seperate filter tank. I found some filter tanks @ www.conservationtechnology.com.
Corrosion-I don't know your geographic location but rain water can be very acidic, especially with all the oxygen in it. I don't think this idea would be good for the tanks considering the sizeable investment you have in your system.
Mike
Corrosion would be my primary concern especially if I use aluminum heat exchangers. I am located on the CT shoreline, I don't know if that is an especially corrosive rain water area or not. I would like to use copper coils but I am having trouble finding them at a reasonable cost.
Check out refrigeration tubing. Less than standard soft coil.
Will
