I have a question about a baseboard not working anymore. My tenant broke the cover of the existing thermostat (wall mounted) , the thermostat is a low voltage one (small gauge wires , 2 of them). The low voltage thermostat connects to the baseboard it has a built in circuit board, it gets activated by the low voltage thermostat. The tenant replaced the low voltage thermostats with a line single pole Voltage one , so he connected the two small wires to it.
This is not correct, but wouldn't this still work ? or is there some resistance inside the Line Voltage thermostat that would prevent the small amount of current to pass through,(heat set to max to make sure ) ? I then asked the tenant to take the wires as they are (connected to line Thermostat) together, this should bypass the thermostat and close the circuit. I didn't tell him to disconnect the wires from the thermostat ,. just connect them together.
I figured this would bypass the thermostat but the heater still doesn't come on. Will it make a different if I asked him to disconnect the wires from the thermostat and just connect them together ?
The breaker is fine and the voltage to the heater is good.
* Edit, would like to add that the original thermostat was thrown out.
* My tenant is not around to test.
![[Hearth.com] Electric Baseboard not working [Hearth.com] Electric Baseboard not working](https://www.hearth.com/talk/data/attachments/287/287773-7dad3df74bd55440013ba49921bf7b7e.jpg?hash=EUl0EqW-dM)
![[Hearth.com] Electric Baseboard not working [Hearth.com] Electric Baseboard not working](https://www.hearth.com/talk/data/attachments/287/287774-1ccc53ae92acf382388742e366a9ca71.jpg?hash=VVKlGonIhN)
